White Rabbit CAD
Post Wed Jan 25, 2023 11:31 pm
Re: White Rabbit CAD
White Rabbit exports PDF vectors perfectly, including curves! ;)
Post Thu Jan 26, 2023 10:32 am
Cool :ob but about Import PDF ?
Because the SVG is some troubling...for mysterious reasons! :oops:
Post Thu Jan 26, 2023 11:17 am
The first thing I will have to take care of is the DXF AAMA/ASTM export. That is actually very useful and helps with professional workflows that wish to integrate 3D visualizations or other plotting environments.
Piece by piece every aspect of integration will get polished, but most important will always be the actual creation features and interaction with sewing matters. That's why the next thing I'm wrapping up is working with projectors. That's super fun and super progressive, too! :hyper:
Post Thu Jan 26, 2023 1:51 pm
We are agree that this Import PDF is an image ?
So no possibility to put it in other part of the prog as curves ?
If you want to see a funny process about this same piece! :) only with PDF! ;)
https://moiscript.weebly.com/uploads/3/ ... est_ok.pdf
https://moi3d.com/forum/index.php?webta ... =10114.505
https://moi3d.com/forum/index.php?webta ... =10114.507
Post Thu Jan 26, 2023 1:54 pm
Hahaha, man, Pilou! :hihi: ...I love playing around with White Rabbit like that, but that's not what it's for, of course.
PDF import is only image based. You can, however, easily trace that in a few minutes and that's actually pretty fun, too! :D
Post Thu Jan 26, 2023 2:02 pm
Yep but the less funny is i can't use the same in SVG! :o I see nothing! :shock:
It's the same for you ? SVG linked
test_rabbit.zip
(4.68 KiB) Downloaded 1149 times
Post Thu Jan 26, 2023 2:31 pm
OMG, that's so dumb... inkscape at it's best!
In the SVG tag it has viewBox="0 0 595,2756 841,8898", which is so incredibly stupid and inconsistent. It should be viewBox="0 0 595.2756 841.8898".
I've hooked up a little protection now, making the next update work better for you, too! :ugeek: 8-)
You can, however, already manually change the "," to "." like I wrote up there. It should work, too. :roll:
Post Thu Jan 26, 2023 2:37 pm
For your entertainment:
Post Thu Jan 26, 2023 2:47 pm
...and some extra fun with it! :beer:
Post Thu Jan 26, 2023 3:49 pm
Ah excellent, i see that you have fully understood the blend of programs! :ob
Rabbit Cad replaces Illustrator & Affinity Designer! c:!
The decimal point of Windows has made another disaster! :mrgreen:
You said that I can change manually the Tag SVG "," in "." but where exactly? Inscape, Rabbit...:oops: :oops: :oops:
In the "SVG tag" is some foggy for me! :oops:
You must be hyper precise for the old eyes ! :D
