White Rabbit CAD
Post Thu Jan 26, 2023 4:13 pm
Re: White Rabbit CAD
Open your SVG in a text editor. Here are the first two lines of your SVG file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg version="1.1" width="210mm" height="297mm" viewBox="0 0 595,2756 841,8898" xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.w3.org/2000/svg">
Check the: viewBox="0 0 595,2756 841,8898"
Change it to be:
Check the: viewBox="0 0 595.2756 841.8898"
Save...
In this file this should be all. :geek:
Post Thu Jan 26, 2023 4:20 pm
If you don't want to do it yourself, here is a fixed version of your SVG file and a HOP file for fun...
Pilou.rar
(17.94 KiB) Downloaded 1366 times
Post Thu Jan 26, 2023 4:47 pm
A damned i made a research with box with respect the letter (B ) :oops: :oops: :oops:
So now of course very easy to remplace! :ob
Thx for all and happy to contribute to kill the bugs! :beer:
Post Thu Jan 26, 2023 5:03 pm
Works like a charm! :ob
if you knew the number of hours spent trying to load something :roll: :roll: :roll:
Post Thu Jan 26, 2023 5:10 pm
That is so cool, Pilou! What 3D prog is this?
I didn't know there was one that would export SVGs, haha, that's really interesting! :)
As for "bug", well, look at the inconsistency of InkScape there!!! That shouldn't be. Why would one write floating point numbers both 1.0 and 1,0? I would pass that "bug" to InkScape, if you asked me. But well...
Anyway, YES, you've helped again to make us stronger!!! :hug: You rock, Pilou! 8-)
Post Thu Jan 26, 2023 5:36 pm
No problem :)
It's the fabulous Moment of Inspiration (Moi3D) The Rolls of ergonomy that i named Ze Zen Nurbs Modeleur" :D
Sweet interface like Rabbit 8-)
I have made the French version of the UI and numerous things! :beer:
(from 18 years ago :roll: )
Click the image for all see! :ugeek: 8-)
And with the Hop fun! :)
Post Thu Jan 26, 2023 9:27 pm
Hehe... it was a bug of Moi3D! :hihi:
I was right! :ugeek:
"This one is a bug in MoI’s SVG export, it should not be using localized number formatting for those values."
Dixit Michael Gibson the creator of Moi3D!
:beer:
Post Sun Feb 05, 2023 9:32 pm
Seems we can't reduce the UI size under something like 1595 * 960 ...does this normal ?
In Windows OS
Post Sun Feb 05, 2023 9:48 pm
I use the fabulous Rabbit for a theoretical convert SVG --> DXF --> STEP file :hihi:
So White Rabbit Cad, Onshape, Plasticity :ugeek:
Post Sun Feb 05, 2023 9:59 pm
1280x753 is the smallest window size for a reason. You can set it, too, under: Settings/Set Window Size
Very cool, we'll have to look at OnShape then! Can it export DXF AAMA or ASTM, too?
