Post Sun Nov 23, 2014 8:36 pm
Helo, this is one of my first tryouts with MUSAGI :bounce: :bounce: :bounce: :bounce: :bounce: :bounce: ... I used also some ARTWORKS from VERVE --- ok, music is not my strength ... I did dislike music-lessons in school times, and I was not good in school - in music ... :shrug: :shrug: :shrug: :shrug: :roll: :roll: :roll:
Case: Lian Li Lancool 216
Post Mon Nov 24, 2014 8:09 am
Between the youtube tags you just place the code number of your clip: VxtnwVLVBmM
When you click on "share" under the clip on its youtube website, you'll see various options. To be sure I always choose EMBED, but then copy out only that last code bit of the url, you know?
Man, you should totally post that in your gallery thread!!!
The music is perfect for it, as it sounds very artsy, haha, with a mild hint of nightmare! Very dark for sure! :twisted:
GREAT JOB! :ob
Post Mon Nov 24, 2014 7:20 pm
Thnx, dear Taron, I will set my series - with MUSAGI FX & VERVE SERIES - in my SIGNATURE :ob :ob :ob .. its better like a double-post. Even I have now a song that reminds me on old TERMINATOR/PREDATOR MOVIES from the late 80/early 90 ..
with drums like in these movies ... BAMM BAMM BAMM BAMM .... BAMM BAMM BAMM BAMM .... BAMM BAMM BAMM BAMM ... BAMM BAMM BAMM BAMM .... :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Post Mon Nov 24, 2014 7:24 pm
MUSAGI : what is the concept of this thing?
Post Mon Nov 24, 2014 7:46 pm
maybe VERVE, if you have suggestion to made similary things like in ALCHEMY - you can create a SOUND EFFECT BRUSH c:! c:! c:! c:! :P ... as a nice funbrush
Post Mon Nov 24, 2014 7:47 pm
its a sound and music engine, you can do lot of nice things, watch drpetters website, even maybe also nice for creating sound-special effects, you can made nice music or effects, e.g. falling waterdrops and so on :roll: ... you can also work with WAV (not all WAV are working, but I use OCENAUDIO too, its similar too audacity) - sounds from internet (but see that you get don't wrong with copyrights) ...
Post Mon Nov 24, 2014 10:12 pm
Don't make me digress like that, Zero! :? ;)
You know, long before Verve I thought of using fluid dynamics for synthesis! In my versions of musagi I've added a synth called "phys" or whatever I called it, and it's basically a permanently swinging "spring", which you can play and manipulate to bring out some amazing sounds. It's literally a sound generating motion dynamics, very similar to the mouse delay I have in Verve now, by the way. Anyhow...around that time I realized that fluid dynamics could produce amazing sounds, probably allowing for flute like playing with all sorts of fascinating resonances and such. One day I'll try that, too! 8-) :rock:
Post Mon Nov 24, 2014 11:02 pm
Sounds go less quickly inside fluids! :D
Else song of whales...
Post Tue Nov 25, 2014 8:43 am
Au contraire mon ami! I believe, sounds go a lot faster and farther under water...hence the whales! ;) :ugeek:
...but those are some of the longers 4 minutes I know of, that's for sure! :lol: :?
Post Thu Nov 27, 2014 8:45 am
hey, I found today, that this is also a very nice Sound-Tracker, Freeware too - its called PIXITRACKER ... just nice Videos too :ob ... I think also a good companion with MUSAGI, because Pixitracker can import/export WAV-Files toooo :rock: :rock: :rock: :rock:
PIXITRACKER is maybe not so powerfull, because only CHIP-SOUNDS - but very very very easy
http://www.warmplace.ru/soft/pixitracker/#intro
And Pixitracker as an VSTI Plugn would be cool :roll:
VIRTUAL ANS s also very cool tool - from Alexander Zolotov
OMG he uses pictures for creating sound c:! c:! c:! c:!
[url]
https://www.youtube.com/watch?v=VclIzvFnuZM[/url]
