Post Thu Aug 13, 2026 1:53 pm
In 5 seconds! With "Sauce Tomate," of course!
You just draw any flat, closed shape—like this L-shape here—and call up a brilliant little plugin called DeckBuilder; everything gets created in one go: the balusters, the stairs, and so on.
If the user gets a wild idea to swap out all the elements, it’s no problem at all since they’re all components!
The balusters could turn into hams, the stair treads into ironing boards... the possibilities are endless!
You just take a screenshot of that greenish "Sauce Tomate" view, pop it into any modern AI tool, and—presto—you’ve got an image or video worthy of Bergman or Doisneau!
Post Fri Aug 14, 2026 5:48 pm
Post Mon Aug 17, 2026 9:50 am
zebra013a.zip
(9.45 KiB) Downloaded 93 times
So, you can actually create surfaces from scratch? That’s amazing! zip english version!
Yes, absolutely! With the two buttons added to the Edit panel, you can generate complete surfaces from the ground up, without needing an initial file:
Add Curve at End: If the scene is empty, this function automatically creates an initial standard 4-point curve. Clicking a second time duplicates that curve—offset along the Z-axis—and immediately generates the NURBS surface between the two.
Insert Curve: By selecting at least one point on an existing curve, this command inserts a new adjacent section via interpolation. This allows you to add as many cross-sectional or longitudinal profiles as needed to refine the surface's shape.
Once these curves are dynamically generated in the interface, you simply manipulate their control points using the Gizmo or box selection to sculpt the surface. The resulting model can then be exported directly as an IGES or JSON file.
Post Wed Aug 19, 2026 11:06 pm
Post Thu Aug 20, 2026 6:56 pm
zebra031a.zip
(16.07 KiB) Downloaded 100 times
Post Fri Aug 21, 2026 7:37 am
Looks like you're having plenty of fun, Pilou! I find it fascinating how this looks and feels like very traditional 3D experiments from decades ago. Nice to see that some passion still goes there! :ob
Post Fri Aug 21, 2026 8:19 am
the more incredible is that today you can code anything without any knowledge of codes' language! :o :shock: :bounce:
Post Fri Aug 21, 2026 8:32 am
"Vibe Coding", yeah, it's quite wild. I'm shocked people can get anywhere with it, because AI isn't all that clever beyond known methods.
Post Fri Aug 21, 2026 10:05 am
It's an octopus that watches everything going on and turns it all to its own advantage! :geek: :ugeek:
New version :) (in English)
zebra033a.zip
(15.71 KiB) Downloaded 86 times
Post Thu Sep 03, 2026 9:51 pm
Even in Free! :beer:
