Mindblowing 3D Art, that looks like a 2D/Charcoal Drawing
Post Mon Jan 21, 2019 3:51 pm
https://www.artstation.com/artwork/wg5wZ
I found it on sketchfab today, but this artwork you can also see on artstation. And here you can read something about the creation-process: https://80.lv/articles/2d-sketch-in-3d- ... 6mVoorVfzk
Btw.... how he did render it? There are no Light-Setups
Post Mon Jan 21, 2019 7:16 pm
Re: Mindblowing 3D Art, that looks like a 2D/Charcoal Drawin
They need to hire this guy to work on Netflix's Dragon Prince, the animation on that show is weirdly eery for its faux-traditional-animated look, this guy's material seems like a bridge over the uncanny valley.
Post Tue Feb 05, 2019 4:48 pm
This is so clever, it almost makes me angry! :lol: :ob Brilliant!
Post Fri Feb 08, 2019 8:38 am
Lighting
I wanted to keep the 3D version as close to the illustration as possible, so there is no dynamic light used. Everything is painted into the texture by hand. I think this is my weakest point at the moment. Figuring out a believable 3D light scenario for an illustration can be challenging both technically and artisticly, and can look pretty horrible very easily. I always experiment with “adding” extra light sources behind the model where the illustration doesn’t describe exactly how the backside should look because I think it’s more interesting to have multiple sources. Even though this is something I have not yet figured out a working formula for, the ideas and “that worked once, let’s try again” mood are already enough for a start. I can only recommend experimenting and sticking to the references, – in the process, you can decide whether that lighting works or not.
