DOWNLOAD VERVE (v0.99z)
Post Mon Jul 16, 2018 3:38 pm
Re: DOWNLOAD VERVE (v0.99v.37)
v0.99v.37 RELEASED:
  • Fluid drying logic improved!
  • automatic saving and loading of window and canvas size!
  • various little fixes
Post Sun Aug 26, 2018 5:06 pm
Re: DOWNLOAD VERVE (v0.99v.38)
V0.99v.38 is up!
  • BUG FIX! When settings change to a new resolution at startup, Average Brush and a number of other features started acting up. Found the problem and fixed it! :ugeek: :oops:
  • New Motion Vector preview, toggle with [v]. It's only a temporary feature, but already kind of fun and interesting! Thanks, Robert! :ob
  • Potential speed up and fix to resolution changes!
Post Wed Sep 12, 2018 9:57 am
Re: DOWNLOAD VERVE (v0.99w.01)
Version v0.99w.01 is up!
Some changes may be more dramatic, others just dramatically "late", if you asked me, haha, but I think this is a massive move forward:
  • Vector Motion View saves into SAVE COMPONENTS, if you froze the action before, using [ctrl]+[d]! It creates an additional "*_vec.png".
  • Smudge with pen pressure on opacity will now act more naturally at fluidity values under 50% by blending more with less pressure and max out at dialed up Fluid Smudge value.
  • [Shift]+[F6] or [Shift]+[F7] will flip current layer only, but it will truly flip its content rather than previewing a flip.
  • Buildup parameter has a more sensible value intepretation now.
  • Layer Bump parameter has a more sensible value intepretation now, too.
  • Window switching between fullscreen [F3] and windowed mode now properly restores the previous window size.
  • JPG saving fix for starting up in a new resolution.
Post Mon Sep 17, 2018 8:44 am
Posted a tiny update, changing the pressure sensitivity on smudge, when you have opacity on pressure. I made it exponential to allow for more softness range when you gently smudge. Bob Ross's "Hair and some air" now is easier to get to! c:! :D
Post Sun Sep 23, 2018 2:04 pm
Re: DOWNLOAD VERVE (v0.99w.02)
v0.99w.02 is up!
Adjusted Fluid Smudge pressure sensitivity...
Post Sat Oct 20, 2018 6:09 am
Re: DOWNLOAD VERVE (v0.99w.04)
A little reminder: IF you run into a crash, please, let me know right away and try to explain as best you can what happened, leading up to the crash! :ugeek:
...Robin, that was a perfect call, I had no idea it would crash and now it won't anymore! :beer:
v0.99w.04 is up!
Post Tue Oct 23, 2018 9:12 am
Re: DOWNLOAD VERVE (v0.99w.05)
v0.99w.05 is up!
Brush#8 has fixed opacity interpolation! Thank you, bwwd! :rock:
Post Mon Oct 29, 2018 11:36 am
v0.99w.06 is up!
Thanks to pud's and his generosity, I've now had the chance to add pen barrel roll to the brush behavior! Massive THANK YOU and a grateful hug :hug: to you! ♥
If you happen to have an Art Pen or any tablet device that registers barrel roll, you are in for some extra fun for sure! :hyper:
Post Sat Nov 10, 2018 12:19 pm
Re: DOWNLOAD VERVE (v0.99w.08)
v0.99w.08 is up!
  • Widgets (temporary gui dials on the canvas while holding keys) will block painting on canvas and let you dial up desired values where ever you are!
  • Chroma Smudge and Smudging improvements
  • minor adjustment and fixes with potential speedup
Post Fri May 01, 2020 10:24 am
I almost forgot to mention... we have no certified Verve and I've added an installer, thanks to Lemivision! :hug:
There's nothing new in Verve, yet, but at least it's an official version, so to say! 8-)
Return to Downloads & Info
