Vervette Fluid Sandbox...
Post Wed Jan 06, 2021 9:02 pm
Re: Vervette Fluid Sandbox...
v1.26
• secret PUD-MODE: hit [p] to toggle fluid processing off, but continue gathering velocities. Hit [p] again to unleash the fluids! Can create chaos and mayhem, but that's the idea of it, too! :hihi:
• improved the other secret [u] key to toggle half resolution on/off. It's also NOT a real feature. Just experimental stuff.
Post Wed Jan 06, 2021 9:44 pm
Quicky of the day c:!
Funny of the story I retake my previous one ( as material image so a sort of fractale process :hihi: ) and make some furious things ! :beer:
Post Wed Jan 06, 2021 10:18 pm
Very nice, Pilou! :ob
Here's a little ode to Pud. Of course, I can't do what you do, but it's just a little example, using a brutal material image. Works quite nicely, I find. :D
Post Wed Jan 06, 2021 10:51 pm
Severe bug! Painting something - Material Image - ok then Key U : disaster! :o :shock:
Only total reset computer save me! Nothing working anymore on my computer! (even CTRL + ALT + DEL) :oops:
sure! :hihi:
Post Wed Jan 06, 2021 11:03 pm
Woops... should be a bit less dramatic now. I just updated it! :oops:
BUT YOU ARE NOT SUPPOSED TO USE [U]... :tantrum: :hihi:
Post Wed Jan 06, 2021 11:08 pm
So I can return or not ? :roll:
Post Thu Jan 07, 2021 12:38 am
Should work. Just don't push it!
Post Thu Jan 07, 2021 1:11 am
So the U key will be closed for some time for me! ;)
Post Thu Jan 07, 2021 1:52 am
You should be able to switch normally. Just don't do what pud did! ;)
Post Thu Jan 07, 2021 12:25 pm
Good Morning, everyone! (well...it's almost afternoon rather, but anyway...)
I've just checked memory usage on GPU and realized that I neglected to delete buffers and textures when I should. Hooked it up and VOILA, all is better!
Pilou, you should now really run no risk to switch around! :ugeek:
