Bug Reports
Post Wed Jul 30, 2014 2:55 pm
Re: Bug Reports
install latest Graphic card driver
__________________________
T !
i find it : )
"beepa fraps"
... for screen image/video capture/record
in games and verve !
Post Wed Jul 30, 2014 4:42 pm
Re: Bug Reports
Have you ever tried it before? Because that commonly means it just can't run on your system. :?
Good advice to update your system. If it is a win8 machine, definitely first update windows to 8.1 or what ever the latest may be and then the graphics drivers! :geek:
Post Thu Jul 31, 2014 3:13 pm
Re: Bug Reports
Hi Taron,
during my first plays with Verve I have found some small bugs. Maybe they were mentioned in the previous post. For sure I try to desribe what I met.
Bugs:
1. If I try to save more difficult project with 4 layers and more I have to wait and wait without any result. I found the way how to continue. I run task manager via (CTRL+ALT+DEL) and back to Verve and voila I can see "Save as" dialog immediately! It looks that Save process got stucked in the infnite loop and only outside signal can awake the process/thread. I tested on my office computer with integrated ATI Radeon graphics and same behaviour.
2. Shift+F9 - experimental merge doesn´t work well on my computer. It produces new layer that contains only data from one of the previous layers.
3. I cannot reproduce now but shape of the interface was included in the painting like a brush trace. I will try to find exact steps to reproduce..
Suggestions:
1. Custom user hot keys mapping would be nice feature to have for the future. The main hot keys (Shift, Ctrl, Alt) are very well defined but I can imagine different settings for layers etc :D
2. Ability to create custom brushes from the original ones.
3. Reset dials for example using double click or something similar.
Verve is really awesome piece of software and have spent very nice time with it. And I am going to spend :) Keep up your good work Taron!! :ob
Michal
Post Thu Jul 31, 2014 3:35 pm
Re: Bug Reports
Thanks Michal,
1. The saving can take a while, thus it might just have been coincidence that your task manager maneuver felt like breaking the loop. Give it a few more tries and just be twice as patient! :? :D
2. Uh...shift f9 problems, that's with which version? If you merge using the interface, does the same thing happen?
3. Sounds interesting, no idea how that could've happened?! Definitely openGL problems!
Suggestions: Thanks, they're all part of the plan already, including even the dial reset. I just have to think of a solution that won't cause accidents to easily.
I really can't wait to get to all of it! :bounce: ...and it will happen! :D
Post Mon Aug 04, 2014 6:00 pm
Re: Bug Reports
not too important but sometimes with shift+tab yet curser doesnot hide. i'am capture full screen and it is shown. see corners of these images viewtopic.php?p=6397#p6397 T*
Post Mon Aug 04, 2014 7:15 pm
Re: Bug Reports
AH yes, I know what that is... for now just keep the brush size a bit larger without pen pressure on size. When it goes to the cross it might pick up the cursor from a different place. I've forgotten about that. :roll:
Post Tue Aug 05, 2014 1:36 am
Re: Bug Reports
T*
Post Tue Aug 05, 2014 7:06 am
Re: Bug Reports
Try the latest again, b!
Post Wed Aug 06, 2014 3:26 pm
Re: Bug Reports
T*
solved sometimes : )
(+edit: full solved)
Post Mon Aug 18, 2014 7:37 pm
Re: Bug Reports
Uh, I see today the first time, that my grid tool is animated, like in a earthquake, or like in a storm or at see ... auf gut deutsch, es wackelt und schaukelt :oops: .... ist bestimmt ein Bug ;) - I use the current version, and I see it the first time ...
LG
