Re: Vervette Fluid Sandbox...
Not even I have gitHub in favorites.
Lemivision wrote:Taron, if you don´t plan to release source code I would recommend obfuscating code asap. The main fluid engine is there!
I am not sure if I understand your thoughts about your PHP solution. PHP file is just on the server side and shouldn´t be visible on the client side! There is no need to hide a PHP file and you don´t have to worry about the keys if you don´t echo them, I think..?
Taron wrote:The fluid engine in there is utterly rudimentary and stuff people can easily figure out. It's climbing to the next level, which is making this so exciting and the full version will show that!
