Lord Insectord gives suggestions
Post Tue Apr 01, 2014 11:27 pm
Re: Lord Insectord gives suggestions
Z A F I O !!!!!!!!
:lol:
Download the latest version now (v0.99n)! ;)
Got it all fixed up and made even a much fancier progress bar during saving! :D
I've tested it with your painting and it has no troubles what so ever. You can now make unlimited layers at practically any size, as far as I can tell. It'll take for ever, true, but it would still save until your HD partition is full, hahaha! :? :lol:
Post Wed Apr 02, 2014 12:23 am
Holy guacamole!that was fast! thanks and really deserved kudos! :D
Post Wed Apr 02, 2014 12:46 am
Fast? Oh, hmmm...yeah, I guess. It's weird, felt like for ever, but...hmm...maybe it was fast. Your mastery motivated me greatly! :)
Post Thu Apr 03, 2014 12:32 am
Given your description of the matter and the little knowledge on programming I have, I expected something like weeks or months... :D
Another possiblity to delete layers: CTRL over the hide button turns the arrow redish, then click deletes.
Post Thu Apr 03, 2014 12:51 am
UUUUUUUuuuhhhhhhhhh! :shock:
I like that! 8-)
I'll do that! ;)
Post Sat Apr 05, 2014 2:47 pm
Another thing, too many times I want to quickly erase something, but I need too many strokes to delete through the buildup, so how about:
Buildup value to affect erasing:
A value of 0 would act as it does now, but 100 would erase through all buildup.
It should have its own value, so while pressing CTRL, user can change the value with B (CTRL+B) or the dial (which btw could change color, or have some kind of visual feedback)
Post Sat Apr 05, 2014 2:54 pm
Hmm, sounds good and I agree! I don't erase much, you know, hahaha... I often use a mild erase to create texture, actually. I really like your suggestion, goes into the mix! ;)
Post Sat Apr 05, 2014 4:05 pm
Got another weird thing going on, wherever I paint now, I get like 1bit color outlines/strokes or something...
And color selection is kind of locked... just moving sliders work, and if once color is changed, I try to paint on the bird layer, everyhing is erased from that point...
I tried all the sliders just in case I had some extreme value somewhere but I can't find anything...
https://dl.dropboxusercontent.com/u/2294713/02.rar
Post Sat Apr 05, 2014 4:18 pm
Ecologic! :ugeek:
Post Sat Apr 05, 2014 4:24 pm
How on earth do you manage to run into such bizarre little bugs?! Weird as heck! :lol:
But I have a solution for you right away:
Go to the problem layer (with fractal blobs), select any color (i took white, but who cares) but set the opacity to near 0...like 5% or so, on the color wheel, of course. Now hit [Ctrl]+[Shift]+[F]. It will fill the canvas, but you won't see anything, because it's such low opacity. Now the problem should be gone. Somehow you've managed to get a negative alpha value, I believe. I don't know where or how that happened, but I'll track it down! :roll: ...wow, it's so sensitive sometimes. Funny how people ideally won't ever know just how careful the coding has to be. :lol:
