Post Sat Apr 15, 2017 8:00 pm
I see you are a renaissance man c:! :mrgreen:
Post Sat Apr 15, 2017 8:34 pm
People like to tell me that! :shrug: ...has to be so, then! 8-)
:beer:
Post Sun Apr 16, 2017 1:38 pm
I feel this tension
That is coming
New version is coming
every day :bounce:
Post Sun Apr 16, 2017 2:34 pm
Oh no, please, don't! Just relax, explore and enjoy as I maintain the existing version until I will begin with a really new one! :)
Post Sun Apr 16, 2017 5:00 pm
I did not download the last version you uploaded, but I downloaded the previous one, the one included CURLS in the vrs.
I tested the vrs as a preset workaround
but I have to say it's not an option, it makes Verve inestable, it gets really buggy (from the first time I try to load a vrs file)
I guess is because of the canvas settings that the vrs records and reopen everytime I want to load a vrs (which happens to be many times).
It makes the canvas texture to be lost or shift, and the fluid of brushes changes so they act differently.
I desist to the Idea of using vrs to load brushes settings, I guess it was ment to be loaded just once at the beginning of the painting process, cuz otherwise it would create bugs afterwards.
also I'm still having problems with the color picker when tweaking the saturation dial after having tweaked any of the RGB sliders, colors still change randomly.
Thanks Advanced Taron, I wait to see the new bug free version of Verve XD
Nice app.
Post Sun Apr 16, 2017 10:24 pm
* Second part of color theory :geek:
I used to have three layers for dual coloring
And now I need one :bounce:
Now the switch instead of the layer became -> .VRS
So alpha is remembered
And it comes out that
The latest verve version does not like the previous ones in the interpretation
.VRS :( for example the minus values in FLUID SMUGE
What's going on with the .vrs interpretation, is that I'm going to get something new fresh :idea:
Post Mon Apr 17, 2017 6:55 pm
Ugh...I'm not sure what is happening there?! :shock:
I can't quite see the version numbers in the video, because it's too blurry. BUT if you had downloaded the v0.99v.18 that I had updated twice that day, I quickly had made a change that made settings saved with the first version of that day corrupt. :oops: ...I did write a warning about that, but it would've been easy to miss it.
It's been an unusual situation and I hope I won't do something like that again, but crazy stuff can happen every now and then, I'm afraid.
But I don't know, if that is really the problem you encounter?!
Have you tried saving settings with the new version and loading them again, see if they work fine? I don't seem to have troubles with that here?!
Even loading v0.99v.17 settings seems to work ok as far as I can tell.
You can always send me one of your setting files that makes a problem. Maybe I can find out what it is. Other than that, the format is very simple. Unless the behavior of Verve itself has changed in a bad way for you, of course, that would be a different story. You are doing some very unique things with it, which partially even escape my understanding, haha, and that is pretty awesome! But scary, too, because I must understand what's happening to see how I can help best, you know.
Post Mon Apr 17, 2017 9:48 pm
Taron please check color picker, it is still buggy, when tweaking saturiation dial after having tweaked RGB dials, color jumps like crazy.
Thanks Advanced.
Post Mon Apr 17, 2017 10:47 pm
I cannot confirm that! Are you sure you are using the latest version? Since I've fixed it, it behaves perfectly fine as far as I can tell?! :shrug:
Check that you are using v0.99v.19, please!
Post Tue Apr 18, 2017 8:23 pm
V0.99v20 :bounce:
