I know UI will be changed completely later, but for existing UI I have some questions - inspirations, experiences, comments.
1. crop/load/save -> this really needs the word on top of each button, like you have done for warp etc..
2.Even me, after working with verve for so many years, I often forget to look at this changing text field and search for load and save, as I am not using hotkeys for that funnily.
What ever you plan with new UI once - skip this text field and find another solution, or make it much, much more obvious and better connected.
For a beginner, I think it's super frustrating. For a "veteran" it still does not work like it should be. It's just a 50% hit at first glance.
3.If buttons have text on it, text is very shy -> almost unreadable until you hoover above. "Image Brush" word is an exception. Words are there to be read first, easy & quick. After, there is design. Specially on a tool like verve, imho.
4. Why is the brush image field that big? I mean the space above the buttons. You are saving so much space on the right, reducing everything to the very minimum. But there you are wasting space? Very taron unlikely.
5. As Tildee said, it would be lovely to have a reset function for tiny little knobs and a numerical input. CTRL+LMB click for reset, double click for numerical input?
6. Icons for paint, erase, smudge and average are not really working visually. They are super big but without real visual information. Common visual language icons could help for paint, erase & smudge at least and are realized in a much smaller way. Average?...hmmm.
7. The overall appearance of verves UI is not attractive & inviting, starting from old fashioned color choice to too much unexplained knobs.
I am a nerd, one who wants to find the easter egg. But verves UI, as it actually is, makes most things much more difficult to visually understand, than it is necessary.
And it is not sexy enough to forgive this weakness.
The main program I am working with is visually almost unchanged since 1990 and very DOS. I am really used to pain.
But in times of smartphone apps doing a pretty attractive UI design layout "in a few seconds", it can't harm to overthink it all very carefully, before doing a new design.
For inspiration:
I really like Infinite painter with it's light design, reduceable to the very minimum. The toolbar is customizable and gives you access to almost everything needed for 80% of your work. But if you go into deep there are very powerful tools to do almost anything.
https://play.google.com/store/apps/deta ... nter&hl=deBut it started quite unfocused and confusing
http://www.trustedreviews.com/guide/bes ... te-painterAffinity photo is pretty as well.
Sure, it is often a matter of taste as I don't like bright UI's at all and I never will.
I am a vampire
Maybe, meanwhile,1&5 would be a lovely gift. Mostly 5
