Post Fri May 18, 2018 12:14 pm
Interesting idea, dear Zero! :ob
Post Fri May 18, 2018 7:25 pm
Thnx, it would b also cool, that a shortcut could change the created color(palets) chronological - maybe the shortcut like X - but not only for 2 colors, but for some more - my suggestion from left to right and from top to down.
Post Fri May 18, 2018 10:17 pm
With GREAT certainty I will make custom shortcuts available and then it's really only a question of which features one would want to have available. I'm almost guessing: pretty much everything and then some! :lol:
...so, yeah, this is for that time then! ;)
Post Mon May 21, 2018 8:29 am
During painting today I was wish - that WRApPING (CTRL + C) will have/save their own Values - because I like to us in 99% hard round brushes #1 and #6 for painting/drawing (I use often +90 / +95), but for wrapping its mostly usefull to have very soft brush-values / Bias -100 e.g. so I have to change my values often between -100/+100. ;)
Maybe also very great, if ERASER can have their own Bias-Values also - so u can switch very hard brush with very soft eraser brush very very fast.
Post Mon May 21, 2018 11:34 am
Absolutely! All part of proper customization! Warping is CTRL+W, though! ;)
Post Mon May 21, 2018 12:37 pm
Sorry, I mean CTRL + W :D CTRL + C is better for a future copy- function
Post Wed Jun 20, 2018 3:08 pm
Have a new Shortcut Idea.
What about the possibility to change the Bias between two Values in very fast way - similar to the [X] Key for changing between two colors. This would be cool. e.g. I like to use a soft edge for the Warp Mode, but a hard for painting. :hug:
Maybe Shift + X or Alt + X? ;)
Alternative suggestion - changing the BIAS values 0-9 with the Num or Numpad-Keys, but with CTRL/SHIFT/ALT
Post Wed Jun 20, 2018 3:15 pm
Well, I still think the "custom brush slots" will be that solution and many of that kind. You can then just create your own brush settings altogether and populate the number keys with them, for example.
Post Fri Jun 29, 2018 3:43 pm
What I am missing almost every time I paint in verve is a "simple" transform tool.
Just scaling would be very lovely. I miscalculate my painting so often and have to rescale.
I know, one can use the image brush as a workaround, which is not bad.
If time...that would be so monster lovely.
Post Fri Jun 29, 2018 6:25 pm
Oh yes, I know. Just the other day I thought about it again. While I was thinking about a meshing tool, too, but that's a different story. Anyway, yes, agreed! :ob
