Shift-I crashes Verve
Post Sat Apr 28, 2018 1:54 pm
When I make custom brushes and delete with shift-I it works. But when I only have one left and hit shift-i then Verve crashes
Windows 10 professional, Notebook with Intel Core i7-6700 4Ghz, 32 GB RAM, GTX 980 with 8 GB RAM, Cintiq 27'
Post Sat Apr 28, 2018 3:48 pm
Re: Shift-I crashes Verve
Use this:
Taron wrote:Hold down [CTRL] and hover over the image you want to delete, you will see it turning red, if there is more than one image up there. Just click on it then, still holding [CTRL] and it gets deleted.
Anyway - don't have this prob here ;)
System: i7 3930k@4,2 Ghz / Titan GTX 6GB / win7 Ultimate 64 Bit/ 64GB Ram
Post Sat Apr 28, 2018 4:37 pm
Hi tildee
you can always use the older version verv to avoid this problem
I use v31
Post Sat Apr 28, 2018 4:43 pm
Post Sat Apr 28, 2018 6:49 pm
I am on v.34 - no problems so far.
Post Sat Apr 28, 2018 7:40 pm
That's funny: It works now???!!! Thank you for your support!
Post Sat Apr 28, 2018 10:37 pm
Ahhh. btw. and completely off topic.
Check out older versions before v.15.
The brush preview for bias was working there but deactivated for some taron reasons later.
Really helps to understand the functionality, even though some brush-bias functions were changed later. ;)
Post Thu May 03, 2018 2:54 pm
:oops: ...yeah, I need to really go at my GUI for the brushes and- well- everything. Thanks for the reminder, Knacki! ;)
Yeah, the brush images can have some weak moments when there's only one image left. Hard to track down the weirdness, because there really have to be very specific circumstances for that to happen. But it's got everything to do with the general chaos I still have to clean up again. I have a really nice approach already figured out, but it requires a lot of work to rework all the code. It's very, very well worth it, though! :hyper:
http://www.taron.de
