Wacom setups for Verve
Post Mon Jul 02, 2018 1:08 am
Re: Everlasting Verve tricks thread
;) got it as well ;)
Now I think all important shortcuts are there.
I left thinks like fluids, brush size (Space+drag) etc as they can be controlled with UI quite nicely.
This it how it looks like when popped up.
Attached the final text file. I really do hope that it's useful for some of you ;)
I will exchange the file in first post as well ;)
EDIT:
Just one download??
Oh, it seems that it is a bit complicated?
So let me repeat and give you an example:
Find attached all you need to edit your Wacom_Edit.dat you can find in (C:\Users\Yourname\AppData\Roaming\WTablet\wacom_tablet.dat) .
I can't guarantee anything as I am using the old wacom 6.3.15-3 driver, but it should work.
I used free sublime text to edit the dat file. Much more easy!
-First make a verve specific pop up menu and assign one silly named function to make a search for it easy.
-Go to C:\Users\Yourname\AppData\Roaming\WTablet\wacom_tablet.dat
-Make a copy of the dat file as backup and save your wacom settings with the preference utility..can't harm.
-Stop the wacom service.
-Open dat with sublime (or anything you prefer)
-This is how it looks in sublime text with the verve commands already assigned in my wacom prefs.. (just the very first entries ;)
-With (STRG+F) you can search in Sublime text for your entry already assigned as a pop up menu for verve.
-unzip attached txt document and copy all.
-go to your entry with the stupid name
-Compare it with my text to see what can be overwritten, and what need to stay there and paste my txt into your wacom dat.
-save
-restart the service again and if everything went fine you will have same executable shortcut list.
-you need to assign one express key to open the pop up menu.
Good luck!!
P.S. This way is also cool to copy a bunch of functions from one prog. to another in the wacom prefs ;)
PopUp-Wacom_v_6.3.15-3.zip
(1.14 KiB) Downloaded 1303 times
Post Tue Jul 03, 2018 7:28 pm
Ahh - that is the place to find it in Wacom properties app.
Final look in Wacom driver.JPG (76.37 KiB) Viewed 22973 times
and the assigned express key - right side - for pop up menu.
assigned Express key.JPG (64.68 KiB) Viewed 22973 times
Whenever I am searching for a hotkey, I press just this one express key. As I made the names with the real shortcut, I can learn them quickly. But no need to, I could just click on the entry and the shortcut is executed. ;)
This makes it so super fast and easy working in verve!
I also assigned some custom buttons like numbers for the brushes, numerical + and - for zoom, as seen in puds thread
http://www.taron.de/forum/viewtopic.php?p=20299#p20299
As I am using the old driver, I just have 8 buttons per window available. Wacom changed later to 25. Anyway some are fine, but most I am happy to have them just as pop up when needed.
But I am afraid, none of you is following me? :D
Post Tue Jul 03, 2018 8:25 pm
Oh, no, you're doing something really excellent there, Knacki! I'm just hesitant to get myself into that, because things are still finding their shape in Verve and are subject to change. If I hook myself into this Wacom stuff, I might get complacent, you know. :P
So, no, no, no, you're doing great and I hope people pick up what you're giving there! :ob
Post Tue Jul 03, 2018 8:40 pm
Shortcuts are for young people! :hihi:
Very descriptive "ArtRage UI" are for oldies ladies! Ergonomy is the master word! c:!
I bet that in 1o years after your UI will be like I say! :beer:
Post Tue Jul 03, 2018 8:54 pm
Haha,
well, if all my stuff looks too complicated, one can just fill those things he wants in the Wacom properties for pop up by his own.
Almost no tutorials out there:
https://www.youtube.com/watch?v=FmY7GiSHpTA
Or use Touchkey to create your own:
http://kannagi.net/touchkey/
https://www.youtube.com/watch?v=XZTmbsopAmk
