GBoGBo's random stuff
Post Tue Feb 16, 2016 9:02 pm
Re: GBoGBo's random stuff
Cool.Have you already written a short tut on that? :D
Post Tue Feb 16, 2016 9:38 pm
Yep Knacki :D !
This is actually a (attempt) remake from scratch of Robert Bosch's Embrace that blowed my mind when i saw it last week:
http://www.bridgesmathart.org/art-exhib ... bosch.html
It is an example of so called "TSP art" (art constructed by solving instances of the Traveling Salesman Problem) with a playout on Verve (and a bit of photoshop color shift on selections).
I did not tire myself a lot because i found all the necessary tools off-the-shelve (freewares) : I used StippleGen2 to generate a stippled image of the celtic disc image that I found on the internet, then Concorde to get the precious closed TSP path (StippleGen2 could not achieve a closed path), then Processing (as usual !) to move the mouse pointer above Verve according to the path.
Input Image (celtic pattern):
StippleGen2 :
http://www.evilmadscientist.com/2012/stipplegen2/
Output image:
Concorde :
http://www.math.uwaterloo.ca/tsp/index.html
Concorde treated the points of the above stippling image as the cities of a Traveling Salesman Problem.
And some useful tools for converting files from/to these different programs :
http://drububu.com/illustration/tsp/index.html
Best regards,
GBoGBo
Post Tue Feb 16, 2016 11:51 pm
http://www.hypatiasoft.fr/index_F.html ;) (exist in English)
There is a demo without time limit but without save AI, SVG !
But you can save your work in program format! :beer:
Post Wed Feb 17, 2016 12:41 am
That's so fascinating, Gbo, crazy! I'd almost want to see this played out with a little bit of fluidity, maybe no curl...lot's of fluid smudge or some other setting... could be fascinating, too... or totally silly, who knows.
Post Wed Feb 17, 2016 6:38 pm
Thanks Pilou for the tool to make my own knots, and Taron for kind interest !
-> With more liquity (and painting instead of erasing) the path is melting with itself :
I don't know... :)
Post Wed Feb 17, 2016 7:21 pm
Make it metallic and color it properly and it will look like an ancient artifact salvaged out of a sunken ship! 8-)
Post Wed Feb 17, 2016 8:55 pm
Yep, ancient metal was my first idea actually ! but i was not happy with the results -> i may give another try !
By the way I tried also the FLUID: CURLS 0% as you suggested and i like the output very much, it's like ink printed on the wrong paper :
:o
Post Wed Feb 17, 2016 9:04 pm
Yeah, like a worn stamp of sorts. Interesting! Have you turned fluid sharpness to 0%, too? Should be a bit different?!
I also wonder what it would...oh, man, there are so many possibilities...nevermind. :lol: :shrug: ...it's just cool! :rock:
Post Wed Feb 17, 2016 10:06 pm
:rock: :rock: :ob
Very cool - just can repeat myself. And many thanks for all the links :ob
Post Thu Feb 18, 2016 7:49 pm
Thanks Knacki, you're welcome. ;)
By the way software-versed guys and gals, i always put my Processing sketches on-line, feel free to have a glance (or even use it - if you can, because it's a bit messy...) :
http://www.gbotet.fr/vrv16/P/ (2016)
http://www.gbotet.fr/vrv/p/ (earlier work, mostly displayed on viewtopic.php?f=6&t=1787)
rgds,
GBoGBo
