Post Fri Jul 25, 2014 1:20 am
@Pilou ;)
Knacki wrote:OK.....I am sure you know how to. If not you, who else?
Anyway, maybe you don't, or someone else.
OK. I didn't found time to do the marbles tut, so I wasn't sure.
But Maybe he didn't think of using it to get a bit more asymmetry in portraits later?
Just a suggestion, borhani ;) Nothing more.
@Tartan
It's nothing against symmetry, I love it. And it's fast.
It's just for faces interesting to get them a little bit off.
After you have done them with symmetry.
And with this technique, I guess all digital sculptors know and use, it's very fast and easy.
So it is in verve.
Post Fri Jul 25, 2014 1:55 pm
Knacki * Pilou * Tartan * ... thanks*
T*
thanks Taron ... thanks for verve * new & new ... brush #7 is too powerful !
Knacki * nice guides, i love more learning & hear others hints. thanks*
Pilou * i am glad when i am in school ! i love tutors & ideas ... & i remember that my marble way inspirated from your sketch
Tartan * i love sculptris symmetry & sculptris asymmetry both ! even i like other types of symmetry ... thanks*
Umgrilla_7 * Dm7 * & other friends ... sorry for taciturnity ...
i know means of Respect and courtesy but really my english is hilarious. i am really thankful from others for watching here.
Post Fri Jul 25, 2014 7:11 pm
Hey Borhani,
Yes Sculptris is a beautiful little program. I am glad Dr Petter created it, as I consider it superior to Zbrush for just pure sculpting fun and concepting. I love Zbrush also, but just as Photoshop and Painter don't match Verve (imho) for pure painting fun, Zbrush doesn't match Sculptris. Once you have your concept sculpting done Zbrush becomes very important because you can take the sculpt to even higher planes. Its a very, very powerful artistic tool. But if I want to start a sculpt, I don't want a lot of buttons in the way and I want more of a natural feel. Sculptris provides that.
I like this last you did. He reminds me of the ancient Egyptian god Maahes. Wiki says his name means " He who is true beside her", the her I am assuming to be Bast his mother. I like that name. Well done :) !
Post Fri Jul 25, 2014 10:53 pm
Cool vivide portraits!
Remeber alchemy symetry use! ;) There also music inside as intricating creation! :)
Maybe soon in Verve ?
http://al.chemy.org
Post Sat Jul 26, 2014 4:51 am
H* Tartan* Pilou* ... thanks*
for me, SC is better than ZB because its smaller and faster for concepts ... i like verve in this way!
and about naming sketchs ,... i forgot it since a few years! because random shapes are rather than random names !
but i like this and do for others in my mind. thanks*
and alchemy ... i am an old user : ) ... i saw in site that may coming soon a new version! alchemy devel toolkit may is nice for Taron too! random forms plus artistic media ... VRV & Alchemy ... LIKE * LIKE * !!
very simple shots from marker study ...
brush 1 & 7 - full bias - dry - no bump & no refection - inverse & buildup colors - gradient-map like layer
with a tine blank preset ... start from brush #1 & #7
marker_preset_b1_&_b7.rar
base of these tests
(23.07 KiB) Downloaded 647 times
basic marker tests - part A - brush #1 is a marker !
01 - b1 + ctrlshift
02 - b1 + ctrl
03 - b1 draw
04 - b1 - n - shift
05 - blue - inverse
06 - inverse gradient - green
07 - inverse gradient - colors
08 - b1 + ctrlshift clicks
09 - b1 + ctrl & ctrlshift - fast_undo brush (low alpfa/opacity)
10 - b1 draw + low_alpha add_remove
11- b1 + low_alpha spin
12 - b1 + low_alpha w_off ctrl vibration
13 - b1 + low_alpha w_off add_remove
14 - b1 - warp - big_shift + fast ctrl - op50
15 - b1 - warp ctrlshift op_50
16 - b1 - warp - big_shift
17 - b1 - warp - big_shift + fast ctrl - op100
18 - b1 - warp - big_shift + slow big ctrl - op100
19 - b1 - warp - magnify in_out with ctrl_ctrlshift - op25 (saved a snapshot ever! it is may auto-change!)
20 - b1 - after warp subforms are soft - save sometimes in warp mode (before!)
21 - b1 - ctrl for dodge eraser
Post Sat Jul 26, 2014 4:52 am
basic marker tests - part B - brush #1 quick start
22 - b1 - pressure based sketch - B pencil
23 - b1 - pressure based sketch - ctrlshift flat blend
24 - b1 - pressure based sketch - add strokes
25 - b1 - pressure based sketch - shift soft (smudge)
26 - b1 - pressure based sketch - paint op40
27 - b1 - pressure based sketch - add-remove cyclet op40
28 - b1 - ctrlshiftM - darker with layer opacity (the base was gray with marker style)
Post Sat Jul 26, 2014 5:55 am
Thanks for sharing! :idea: Love these overlapped transparent circles.
Post Sat Jul 26, 2014 8:37 am
Water colors! 8-)
Post Sat Jul 26, 2014 2:02 pm
maniakid * Pilou * ... Thanks : )
کسی که میبخشد دارا‌تر است و کسی که یاد می‌دهد داناتر. من سعی میکنم اینطور باشم. از توجه شما متشکرم.
ورژن‌های جدید هر بار افکت‌های طبیعی‌تری ایجاد می کنند و این باعث خوشحالی و انگیزه برای تلاش و نقاشی هست.
& parts about #7 basics. with the same marker preset (last attachment) ...it is more fun and mix of them is more more : )
(my tests often with an old CRT and may to bright sometimes)
b7_01 - buildup marker opacity100
b7_02 - burn-dodge opacity50
b7_03 - gray color opacity75
b7_04 - 1 gray - 2 color
b7_05 - 1 stroke with more 2 tones
b7_06 - cross colors
b7_07 - color with pattern
b7_08 - z-toggle cyclet
b7_09 - offset curves
b7_10 - offset spin
b7_11 - quick start
b7_12 - add remove - freely - form with dodge eraser
b7_13 - add multiply layer
b7_14 - screen mode - low opacity
b7_15 - play-manage add-remove posterize-steps
b7_16 - ready_for_shift
b7_17 - shift_op75
b7_18 - op100
b7_19 - op100_warp_shift
b7_20 - op100_warp_ctrlshift_a
b7_21 - op100_warp_ctrlshift_b
b7_22 - op100_warp_ctrlshift_c
b7_23 - op100_ctrlshift_blend_no_warp
b7_24 - op100_75_25
Post Sat Jul 26, 2014 2:21 pm
25_before
26_ctrlshift_warp
27_shift_warp
28_ctrl_warp_op_50
29_ctrlshift_with_white_op50
30_ctrlshift_with_red_op50
31_ctrlshift_colors_op100
32_drag_with_F6_F6_F7_F7_w_off
33_marker
34_chalk_ctrlshift_with_vari_ops
35_import_linework_on_new_multiply_layer_and_paint_on_Background
36_screen_layer
37_brush_8
38_brush_7_blender
39_brush_8_blender
40_brush_7_with_undo_brush_z_circles
41_7
42_smal_changes_for_blend_details_with_e_on
43_in_new_layers_colors_are_not_inverse
44_ctrlshiftM_to_gray
45_inverse_tint
46_duplicate_layer
47_W_E_on
48_W_E_on_layer_op40
49_W_E_on_layer_op100
50 try!
