GBoGBo's random stuff
Post Sun Feb 07, 2016 6:26 pm
Re: GBoGBo's random stuff
@Gbo about last ethnic image
Have you some "hot points" for past images without offsets ?
Post Sun Feb 07, 2016 6:44 pm
Hi Pilou,
I pressed A to have non rotating stamps; after some tries, i decided not to use the self-repeting feature of Image Brush (it was difficult to get gapless prints), instead i printed each stamp separately with the mouse. Because the brush image is displayed all time long, it is perfectly possible to adjust each tile side-by-side by hand, but it was less painful for me to do a little program (with Processing/Java mouse Robot) to locate the stamping positions with the required precision.
This short video clip explains it better :
As you can see with the Image Brush set, the overall pattern is generated from a random selection of a single special tile, instanciated in 4 rotations at 90°.
Because of the possibility of random selection of the brushes (good shot Taron !), each ouput is unique, another go will give a similar but different overall pattern (watch carefully the 2 images in the previous page).
More explanations and original work from Robert J. Krawczyk (i have duplicated the tile from his example called "A Path of Your Own 013") :
http://bitartworks.com/paths01/gallery01.html
regards,
GBoGBo
Post Sun Feb 07, 2016 8:25 pm
Oh, your pattern looks fantastic, GBo! And I like the venner that it has. :ob
Post Sun Feb 07, 2016 10:34 pm
@GBo
Ah ok that was a little prog! :beer: But if it was inside Verve that will be more cool! :mrgreen: Taron will cooking this without any doubt! :D
You can incredibly increase your results in modifying your module because it has now a diagonal symmetry! ;)
And of course another way is also increase the number of junctions by sides (now 3 for your module)
It's amazing how a very simple pattern can create some crazzy organized chaos! c:!
Cool site of Robert J. Krawczyk of images combinations! c:!
I have a plugin inside Sketchup by SDmitch who can make the same! :ob
(Random components replacement) You draw some empty cubes, and a familly of filled cubes et voilà! 8-)
Here in 3D! ;)
Post Sun Feb 07, 2016 11:30 pm
Gbo, that's so cool! 8-)
Great idea! :ob
Post Mon Feb 08, 2016 12:56 pm
Top!!!!!!!
Post Mon Feb 08, 2016 8:37 pm
Lemivision, Pilou, Taron & Knacki, thank you !
Post Fri Feb 12, 2016 7:12 am
Wahou seamless pattern with brush! Impressive! :bow:
Post Mon Feb 15, 2016 12:11 pm
Brilliant ideas here GboGbo! I wish I had more time these days because they are inspiring c:! :D
Post Tue Feb 16, 2016 8:32 pm
Thanks a lot amigos !
More*
