last version ...s
Post Tue May 06, 2014 4:38 pm
Re: last version ...s
I have only something when I make this
Mode Wrap enabled
Shift + Ctrl + draw = something but it is not an inflate
then Ctrl alone on this drawing is something that can be be an inflate!
So in my opinion there is something wrong in the test of the keyboard... speed of the answer of the keyboard...
Post Tue May 06, 2014 4:43 pm
Makes absolutely no sense at all! The snapshot you were showing earlier does exactly the right thing, but with the wrong brush, that's all. :shock: :|
I can't tell what you're doing, but I can tell you that it quite obviously works.
Try going down with the opacity to like 10% or 20% when using brush 1 or 6!
Post Tue May 06, 2014 4:45 pm
Wait other advices of other users on this function! :)
Post Tue May 06, 2014 4:50 pm
In fact that is not an inflate, but the redraw of the previous drawing! :ugeek:
So for me the Inflate function don't exist! :)
There is a vicious glitch! :)
Maybe you have not posted the last ultimate uptaded version ?
Post Tue May 06, 2014 5:34 pm
Pilou wrote:We can't say that is an Inflate of the first image! I have just the new paint of the brush!
This picture shows definitely that it is in fact working just fine! You are just using it with brush #2 (or #3, but I guess #2).
There's nothing else I can tell you, Pilou, but to wait until somebody confirms that there's trouble elsewhere! :geek:
Do this:
1. Paint some crap on the canvas
2. hit number 1 on your keyboard
3. go into warp mode [ctrl]+[w]
4. go to color wheel and lower opacity to around 20%
5. hold [ctrl]+[shift] and carefully wriggle in one place while painting.
Does it not look like the painting is bulging at this location? :|
By the way, it will not bulge existing warps you've done already in the same warp mode session. It only bulges what's on the painting!
Post Tue May 06, 2014 11:26 pm
Hum hum!
Maybe I had confused Opacity of the mouse wheel and the Opacity of the Bottom menu! :mrgreen:
in your video 6, seems at 9.45 you don't change anything (opacity 20%) for make the inflate!
All is 100% visible
OK that what that! :D
Maybe just a special click for mouse user for inflate SHift + Ctrl for simulate pressure (?) of the Pen graphic?
New mystery! :)
Seems only 1 or 6 upper keybooard take the Brush 1 and Brush 6 and not the Numeric "separated right keybord" 1 or 6 ! :shock: :shock: :shock:
Does this normal?
Not inflates following just Pilouterie for relax of the headache inflating :)
Post Wed May 07, 2014 12:04 am
Nice one!
Numeric keypad is not used. Only the standard number keys select brushes.
In the video I use my wacom tablet, as I always do, and "inflate" responds to pen pressure. With the mouse it would inflate too fast at 100% opacity.
Post Wed May 07, 2014 4:56 am
like*
@Taron
please "verve recorder button" !
(such as "open canvas event'/"speedy painter recorder"/"corel painter script")
for repeat, share & Learn & for verve!
thanks*
Post Wed May 07, 2014 1:13 pm
If only it was that easy, haha, but it is part of the plan! 8-)
jim
Post Wed May 07, 2014 4:17 pm
Everythings working A-okay here
Really promesing new features, thank you very much :)
i also just gave the "High Quality" mode some proper work on the highesr resolution.
my GFX card's fan does speed up quite a bit but the fluids are absolutely smooth.
Though, my system (in the signature) is probably a bit higher than the average and not a good reference.
Anyway, i sure am excited :twisted:
The smooth look is really nice but it does steal quite a bit contrast imo? :?
i thought maybe an AS path that looks for the darkest and brightest pixel in the image and excludes just these from the AA.
ie. to keep spec highlights and shadows crisp and blur the rest.
