Taron wrote:...
Layers have only one less obvious feature and that is Delete. Select the layer you want to hide or show, hold and drag right to bring up the Delete Layer requester.
The layer panel itself may come across a bit funny, because the dials you find at the top of the layer panel are always only for the currently selected layer!
Ok, there are two less obvious features now since v0.98:
- merge layers Hold down [Ctrl] to change the "add above/below" button on the layerslide to "merge above/below".
- copy layers Hold down [Shift] to change the "add above/below" button on the layerslide to "copy above/below".
