Bug Reports
Post Sat Jul 12, 2014 11:55 am
Re: Bug Reports
i like new layer opacity mode
and i never select between my great options! 1+2>3 !
an old question about shift+f9 :
it not works normal for me or ... or i dont know how to use ...
can you make an easy & simple tutor or post before & after shift+F9 with explain ... i use it only for fast decrease unwanted layers ! or really exprimental change.
click-merge (blue cursor) works fine but what differention between these two commands?
اگر یک راهنمای ساده تصویری درست کنی من با تفاوت زبان و دقت کم هم راحت متوجه میشوم. برای دیگران هم مفید خواهد بود.
Sorry & T*hanks T*aron
Post Sun Jul 13, 2014 6:08 am
Re: Bug Reports
:oops: WOOPS! I totally forgot about that, haha! Thanks for reminding me, b!
Just fixed it! :D
Now it works exactly as in the layer interface. Except it's always "merge below", merging the current layer down to the one beneath it!
Post Sun Jul 13, 2014 7:58 am
Re: Bug Reports
T*
shift+F9 working
but after that, that layer locked to smudge mode and no paint colors
but after some figure or alt+tab its back to paintable layer.
T*
Post Sun Jul 13, 2014 8:58 am
Re: Bug Reports
Oh...crap, I was sloppy, sorry!
Also, I took off the confirmation window. [shift] should be clear enough a choice.
Post Sun Jul 13, 2014 2:12 pm
Re: Bug Reports
T**
هر دو تغییر عالی بود
Post Tue Jul 15, 2014 6:52 am
Re: Bug Reports
3 cases about GPU bugs
sharp square instead soft circle [shift-smudge].jpg (141.71 KiB) Viewed 15846 times
red fractal scale brush instead [ctrl-blur] [r].jpg (158.07 KiB) Viewed 15846 times
square fractal in warp-mode [r].jpg (205.39 KiB) Viewed 15846 times
i like glitch & fractal effects but i like sharp brush and soft effect too.
... & about save
layer to png worked (ctrl+s is ok) & save to col-mat is ok
but i have not safe merged png save. shift+s png is a black only file.
sorry & T*
Post Tue Jul 15, 2014 8:03 am
Re: Bug Reports
Cannot confirm saving troubles. [shift]+[s] png works just fine here! :?
PLUS there's no difference whatsoever to before! That means it has never worked for you?
The glitch can happen if 0% fluidity is used on a large brush (mostly #6) with size pressure on. I can fix that, I believe.
The other stuff I can't yet replicate. Any English speaking person around, who can confirm that and describe the problem?
Oh, you're talking about "Brush Blur" modes? Oh yes, they'll do wacky stuff in warp mode...sorry about that. I should block those there!
But I cannot replicate what you're doing there, that's really weird stuff.
Thanks, b. Put your graphics card into your signature, please!
Post Tue Jul 15, 2014 10:42 am
Re: Bug Reports
yes, it has never worked for me
shift+s PNG is an old bug but we save to jpg instead with lower Quality
viewtopic.php?p=1920#p1920
and vrv saved files yet open with diagonal glitch
_________
here a screen record
http://s5.picofile.com/file/8130180000/ ... s.avi.html
AMD phenom(tm) II x6 1055T processor 2.80 GHz | AMD Radeon HD 6800 series | Ram 8 GB | vista.U.SP2.64
T*
Post Tue Jul 15, 2014 12:21 pm
Re: Bug Reports
W O W, borhani! You're graphics card is over 4 years old!!! AND an AMD on top of things, haha. I'm literally baffled as to why it works at all, EVER?! :lol: :o :shock:
Sorry, man, there's nothing I can do, but I'm thrilled you could ever work with Verve at all!
You might want to consider getting a new card, if you get the chance. :|
Sorry, really, but that's just out of my hands.
Post Tue Jul 15, 2014 12:48 pm
Re: Bug Reports
خب اشکالی نداره
ممنون T*
خیالم راحت شد : )
