Feed Back 0.99.v 13
Post Thu Jan 28, 2016 9:41 pm
Re: Feed Back 0.99.v 13
Compare please with the old version.
brisize old
Post Thu Jan 28, 2016 9:47 pm
Taron wrote:AH, no, it's just a positive "bias" (vertical), try to use negative bias for horizontal flatness and you'll see... [...]
Negative bias works indeed, thanks Taron ! :rock:
Another thing, since it is the first time I jump on "v" versions, I notice that liquids works VERY differently than "u" versions. Liquids tend to become fuzzy at the edges, and a quick stroke is doing like a water storm, distording also the surrounding strokes already on canvas, making them fuzzier, or kind of "waterier". This is new. Do you experience this ? is there a way to mimic the ancient behaviour ?
Thanks
Post Thu Jan 28, 2016 9:49 pm
@Taron
You somehow linked this sizing with mouse speed? When one changes fast (sweep with mouse) bristle size it gets good animation and sizing, but if it does slowly it changes the settings minimally. I think you should have fixed scale for this, not depending on mouse speed.
Post Thu Jan 28, 2016 9:50 pm
AH, haaaha...ouch... :oops: ...it ignores the pressure knobs for the bristle size. If you make a fast stroke they swell, right?! :? :lol: :oops:
I'll fix it for you... ;)
OH, you were faster with your comment, hahaha... danged. So, yes, that's it!
Post Thu Jan 28, 2016 9:58 pm
@GBoGBo
Yeah I noticed that also with fluids, when fluidity is set high.
Had no time to experiment more with that but kinda liked it, as they are now more like watercolors :D
Post Thu Jan 28, 2016 9:59 pm
Uh, after I use tablet and pen it works with a mouse too. I cannot reproduce the issue now. Dont´worry about that. I will try to find steps to reproduce.
Post Thu Jan 28, 2016 10:00 pm
Ok, Try it now! :geek:
Post Thu Jan 28, 2016 10:05 pm
Yeah, Zen correctly described the issue and you correctly fixed it. I am happy now! :) :ob :beer:
Thanks! :)
Post Thu Jan 28, 2016 10:21 pm
Post Fri Jan 29, 2016 9:16 am
zen_ wrote:@GBoGBo
Yes indeed zen_, "v" versions of Verve are more watercolor-like than "u" versions when fluidity is set high, that's nice, but "u" versions had sharp edges on fluid splashes, that is also desirable in some cases. I'd like to know if the behaviour is (or can be made) settable ?
regards
GBoGBo
