Post Thu Aug 28, 2014 7:57 pm
Hey Lemi, all on the list already, but I do like "*.vrb" ...that will be the extension for brush settings for sure! :ob
Post Fri Aug 29, 2014 8:36 am
vra , vrb , vrc , vrd , vre , vrf , vrg , vrh , vri , vrj , vrk , vrl , vrm , vrn , vro , vro , vrq , vrr , vrs , vrt , vru , vrv , vrw , vrx , vry , vrz , vr0 , vr1 , vr2 , vr3 , vr4 , vr5 , vr6 , vr7 , vr8 , vr9 , vr: )
colors , important numbers , UI
colors
it is very rough and draft but say my idea ... a simple note for UI ... selected/load/custom mode ... http://s5.picofile.com/file/8137700284/lite.jpg
and a suggest for more simple control ... colors and important numbers ... ratate buttons may be in verious colors for faster view and find ... for example fluidity emount may a spesial BLUE and dry speed may a kind of yellow and push can have a gradient between to variation of red ... this nice for assign and find and new features have a new colors ... you use this idea in pressure-opacity-blur-toggles ... and if we have a custom load it is help to fast toolbox and artist friendly full.
and in 2nd level they are can have a lighness or saturation gradient multiply for amount of fluidity or speed ... one H_S_L based data can aware artist fast and visually learn-able without need to high memory!
color may are simillar but even this way is too useful and in all workspace is intresting ...
if this way is not your idea, you can set multi skin ... skin as a changable cloth or watch or car... but colors is better and faster and pre-learned.
numbers
ok we have a ranges of numbers in several features ... control of them may a bit difficult and if we intermediate may hard ... i have a simpler suggestion
when you add a feature i do two works:
1- test freely
2 - number tests
freely for greeting and visit ... for welcome t new freind and numbers for control and use ... min, average, max are 3 numbers at first and i try use it with compose to other features with min,average,max of theris numbers ...
this way is more faster from all numbers and is possible for each user then with a bit more test , i find the numbers that have a different state and behaviour ... in all almost each feature have 5 golden level 0 - (1-5) - 50 - (95-99) - 100
... well ... if we need a simple UI we can change a rotate button to 5 ot 2 numbers ... moe amd more simpler ... a mobile version! but yet have almost all options!
and in other simplest version you can hide some options in lite mode and set those to optimise 90% of times. for example i use normally buildup on 100 and pressure size is on ... i can use and control with a toggle or just one hotkey with a smaller control pannel and mor joy to custom artpad.
tree toolbox
and another for smaller and simpler ...
a small box with toggles,color, or only very important numbers . simpler than current!
and if we toggle on fluidity speed, it shown that option pannel with all settings and after it re-hide ... and its may have brief and code-like infos with some colors of digits near toggle button ...
in simple say a tree base option for view and change
or in pre-version a property box/bar or even a screen monitor or status bar
Post Fri Aug 29, 2014 9:06 am
[img]vector%20fluidity[/img]
simple idea box ...
listen to this idea please!
we why needs fludity painting? ... an important question really for verve. ...
with fluidity random is easier and paint is cooler, some shapes and forms paint better and artist can more freely paint, the result may more artistic and more natural view ... and some reasons that you know better.
but
fluidity changes solid things ... more fluidity means newer things from we paint ... non 100% control-able ... ok ... we adapt with this tools and try achive better and more ...
: fluidity is good and is bad sometimes and sometimes ...
ok my suggestion: as that i saw before: dry fluidity! ... hehe ... yes ... when you add OSC feature i think very to extend this idea ... control+ dry base + generative effects + random and chaos + mixable with fluides ...
and when you add color push , we have a new option about control of fluidity more ... this is a golden achive idea ... more control of fluids ...
oh & i what i say: verve is a bitmap painter but it can use vector world tools, alchemy and sai and synthetic studio artist use it in direct and photoshop use indirect with illustrator ...
vectorize methods are different and artistic freiendly and this world is too big.
i suggest to use vector suggestions for bitmap puzzles ... fluidity with vector graphic may be too faster and incredible.
i know that this suggest is too big and may not in your roadmap but please study and think more. i hope verve have a vectore dimention too.
i use inkscape for many years. it have some nice idea to verve ... tweak tool, L-system, symmetry modes,tracing ideas, ... some pics for view. thans for listening T*
http://en.flossmanuals.net/inkscape/toolbox/tweak-tool/
http://design.tutsplus.com/tutorials/wa ... -cms-20709
http://dev.inkscape.org/screenshots/gal ... akaroo.png
http://dev.inkscape.org/screenshots/gal ... aving1.png
http://dev.inkscape.org/screenshots/gal ... aving2.png
http://inkscape.13.x6.nabble.com/file/n ... rrange.png
http://dev.inkscape.org/screenshots/gal ... mplify.png
http://dev.inkscape.org/screenshots/gal ... tiles1.png
http://dev.inkscape.org/screenshots/gal ... tiles2.png
http://dev.inkscape.org/screenshots/gal ... nclump.png
http://dev.inkscape.org/screenshots/gal ... ffects.png
http://dev.inkscape.org/screenshots/gal ... nmayer.png
http://dev.inkscape.org/screenshots/gal ... mental.png
Post Fri Aug 29, 2014 10:32 am
Let's go easy on me and see if we can avoid giving me nightmares, please! :o :? :PP
Once upon a time I told someone to run by me one idea at a time. Or maybe up to three ideas... but I'd prefer one, please! :|
I had to laugh at the first image, though, hahaha.... my plan is not to add any more parameters before I have started with the "real interface". :geek:
Thanks, though. :shrug:
Post Fri Aug 29, 2014 10:54 am
OK :shrug:
Post Fri Aug 29, 2014 7:45 pm
Elegant response Taron
Lol
Post Fri Aug 29, 2014 9:34 pm
LOL ... OK : )
من وقتی دوستم به سکوت نیاز داشته باشه این کار رو انجام خواهم داد.
+ when my friend need to silence, i do this.
(google-translate works sometimes to wrong! and inverse!)
Post Sat Aug 30, 2014 5:22 pm
What about some more layerblendingtypes? Because some digital-artists say, thats good to start painting first only in black & white ... and colorization you should made after this. So it would be nice, to have some more blendingtypes in the future? :roll:
Post Sat Aug 30, 2014 8:56 pm
Yep, those are definitely coming, too!
I do like doing that sometimes, too, and you can do something like that already. Anyway, it's coming! :)
Post Sun Aug 31, 2014 11:02 am
Thats great too ;)
I have also an idea for saving PRESETS, what abou some check/uncheckboxes? Sometimes its nice to save/load only some settings ;)
