Post Fri Sep 12, 2014 2:06 pm
Nah, that (tiling) would only work for "conventional" paint apps. Verve's fluids couldn't work that way. Well...they could, but you wouldn't want it, trust me! Fluids would only work right to the border of the visible canvas, you know.
I could do some weird stuff, where I'd dampen fluids towards the border of such tile to avoid ugly breaks, as well as some weird solutions, if someone zoomed out, where I wouldn't change the resolution of the fluids, but ...nah, that wouldn't work either, because they affect the actual pixels of the final image, which would have to be in VRam at that time. So....there may be some tricky ways to deal with it, but I'll have to investigate later on into possibilities.
THANKS, though, of course! :ob
Post Fri Sep 12, 2014 7:58 pm
Hi Taron,
I just noticed a cool effect when I color-picked an area that was bright due to being part of a layer with the [+] attribute.
The RGB #'s where above 100% and it was if I could paint with light anywhere I wanted! :o c:!
Would there be a way, like a knob to add that "lit" quality to a paint color value without doing so on a [+] layer?
Essentially giving you over+100% for RGB.
I'm assuming these values are above max level for standard diffusion illumination....
Gosh... I wonder if the OpenGL gives the option for vectors to illuminate light? (sounds far fetched).
I'm painting with light! :bounce: ....OKAY!! I WAS... now it's not doing it.
It must have been a fluke. :?
Post Fri Sep 12, 2014 10:44 pm
Eh... [m] toggles additive/normal mode for painting, so it's not a fluke. You can boost a color on the same canvas to any percentage, hehe, but well... when you pick it, it should give you the same >100% color.
BUT I will later on add more wacky stuff for paint colors, such as illumination or rather ignoring the light.
I will also later on add more light sources, by the way, but anyway...
Post Sun Sep 21, 2014 7:24 am
Hey dear Taron, what about that, that VERVE can safe in his Memory a couple of colors, 2, 3, ... 5 ... and the possibility to switch them fast during painting? c:!
Hotkeys e.g.
SHIFT* + 1, SHIFT + .., SHIFT 5 c:!
or near C - X for Backward-Switching and V for forward-switching :P
and SHIFT* + C for saving color
* or CTRL or ALT
Post Sun Sep 21, 2014 8:39 am
Download again! 8-)
It's really just temporary, but hit [x] to switch between two color slots! ;)
Post Sun Sep 21, 2014 8:51 am
Thnx, so nice that you work also in this feature c:!
Post Sun Sep 21, 2014 8:56 am
You caught me at a perfect moment! :)
Post Sun Sep 21, 2014 9:05 am
:oops: Small fix! Download again! :roll:
Post Sun Sep 21, 2014 9:15 am
I just switched it over to [x], like in photoshop! I think that's more pleasant for most! :ugeek:
Post Sun Sep 21, 2014 10:04 am
ThX *
