Post Sun Sep 21, 2014 3:13 pm
Wow! I actually use [x] a lot in PS, is there some small swatch or indication to show each one? (will find out Monday)
Post Sun Sep 21, 2014 3:58 pm
I'm not planning on adding more to the temp interface, you know, but later all this will be rather different to begin with. We shall see!
Post Mon Sep 22, 2014 5:56 pm
lightless mode (full flat and solid colors and canvas for better vectorize, tiling & edit) . some styles not need any bump. now we can export flat_color layer but this is nice for view and screenshot too. T*
Post Mon Sep 22, 2014 8:05 pm
Yes, I wanted to add that almost from the start. Just a little switch to toggle lighting on/off. Maybe I'll hook that up tonight, not sure.
Post Tue Sep 23, 2014 7:22 pm
Hey dear Taron, I have new idea too, now we can switch between two colors (with x) and also between two values (with m) - what about a possibility to can set an gradient between these two colors/values ... different gradient by pressure (graphic tablet) and speed (mouse / tablet) and maybe also by timeloop and randomized c:! c:!
Post Fri Sep 26, 2014 3:35 pm
good news and ideas **
Post Fri Sep 26, 2014 4:23 pm
Interesting idea, Zero!
Post Sat Sep 27, 2014 7:14 pm
Hi Taron,
There is a little regression on last u.33 of today, on my PC the angle of flattened brush 9 now follows the direction of the stroke. Since u.31 positive Bias used to flatten the brush horizontally, negative bias vertically, and followed the azimuth of the pen, which was a great feature. Maybe there could be a way to chose between the two behaviours (i.e. u.31 / last u.33) that may both be useful ? Also I wonder if there is a possibility to freeze the angle of all flat brushes (7, 8 and now biased 9) at any moment by toggling F key for instance ?
Thanks Taron !
Post Sat Sep 27, 2014 8:15 pm
Yeah, I'm giong nuts over this... I think I'll have to improve the brush interface, too, adding a few options.
BRUSH ROTATION: fixed (adjustable), automatic (precise, smooth), pen tilt.
Post Sat Sep 27, 2014 9:28 pm
I just had another look and changed it back... try it now!
