IMPLEMENT, IMPLEMENT!
Post Sun Jun 29, 2014 7:52 am
Re: IMPLEMENT, IMPLEMENT!
ورژن جالب و تستهای بسیار خوبی هست و برای من آموزنده بود
از هر دو شما متشکرم
Post Sun Jun 29, 2014 8:23 am
:lol: O M G :lol:
That looks SOOOOO hilarious and actually brilliant on top of it. Those scales are perfectly unique!!! :lol: AWESOME!!! :D
Post Sun Jun 29, 2014 10:41 am
But careful than too much functions kill the prog! ;)
jim
Post Sun Jun 29, 2014 11:48 pm
Feature richness is only problematic when the UI becomes too intrusive or once, you run out of shortcuts :lol:
Also if one is obligated to deal with complicated mechanisms :? i am sure that Taron will keep up Verve's simple launch- and paint nature, on the surface anyway 8-)
Though, i wouldn't mind some more sophisticated influence under the hood, eventually :twisted:
... Actually, this tool is too cool to reach for it after all :lol: ... Also, It's my own fault of course but, i keep ressing [t] for some reason :? then apply paint thinking that im holding down [z] and can't undo again. :oops:
Does [RMB] do anything, yet? Wouldnt mind it occupying that place that is, at least until you found something more suiting for that spot? :) (i have [RMB] and [MMB] on the two pen buttons ;) )
Hmmh, a alternative bg-brush/color would be kinda nice for [RMB] aswell :P ... now, i'm not sure anymore :?
How come you aren't useing [RMB] anyway? do you have something special planned for it? :mrgreen:
In any event, ... i think i'll just glue a pice of sandpaper on my [z] button :lol: ... Brilliant. 8-)
Edit: Ah, and speaking about shortcuts ... How about if ([MMB] hold)+([LMB] up/down) was zoom, as well? ;)
Post Mon Jun 30, 2014 12:15 am
What make exactly [z] because i wonder by hasard if French keyBoard Azerty gives same result than Qwerty one ?
jim
Post Mon Jun 30, 2014 12:30 am
You can now use the brush to undo just where you paint, while you hold down [z] :o :D
Should be whatever same button you usually use to undo ( [Ctrl]+[z] )
Post Mon Jun 30, 2014 12:42 am
Only one time for the last stroke ? And I must redraw over my last strokes ?
jim
Post Mon Jun 30, 2014 12:52 am
Well, it's for your very last "Action", whatever that was ... Stroke, Smudge, Transform, Warp ect. Just like undo was before, just that you now can choose where in your image you want to undo and where not. :shock: :D
And yes, you have to remember what you did and where ;)
Post Mon Jun 30, 2014 10:56 am
That's the problem!
Z make absolutly not like Undo (Ctrl) : there is no visual take back when I press it or Hold it! :shock:
I have same problem with the "magnify Glass" seems not works for me! :o
I suspect a blender between French and English keyboard!
Post Mon Jun 30, 2014 12:05 pm
You guys figure it out, I believe in you! :)
