Animated Brush Repository
Post Wed Jan 20, 2016 11:41 pm
Found time to play with the new brush function.
Let us share some stuff!
Grass (lock brush tilt with SHIFT+A):
Two brushes -> two stroke grass line ;)
The file:
Grass.zip
(134.23 KiB) Downloaded 1541 times
Post Thu Jan 21, 2016 12:08 am
Re: Animated Brush Repository
Stars for brush 10
even though one can do stars with ease in verve, with those brushes it is even easier as you can stroke fast and crazy and always get dots.
Put osc chaos high to avoid repetitions.
The file:
Stardust.zip
(73.85 KiB) Downloaded 1492 times
Post Thu Jan 21, 2016 12:21 am
VERY COOL STUFF, Knacki! And a great idea to start a thread for that! :ob
I'll join shortly! ;)
Post Fri Jan 22, 2016 2:00 am
Leaves:
Download file...it's a rar done with 7zip. Hope this works. never uploaded there before.
http://www.netupload.de/s/221/C71hHHRy.html
Post Fri Jan 22, 2016 2:12 am
Grass V2
8 Min grass session ;)
This is a pretty cool grass brush.
Use it with size pressure, adjust min Size as needed, and opacity for sure. And combine it with my other brush for clumps (hope that's the correct word)
Only mistake I made is that it is painting below pen tip as I saved images not in the center.
Still learning. Adjust spacing would be cool i.e. if not already possible?
File:
http://www.netupload.de/s/221/swqCOnag.html
Post Tue Jan 26, 2016 12:58 am
Seems we can use some alpha like these free ones ?
Another infinite game! c:!
Post Tue Jan 26, 2016 1:29 am
You could get those over a detour using photoshop CS5 or lower to create some brush there and then with Lemivisions converter into a Verve brush, sure!
Until I have written a 16bit import for Verve, I won't bother loading 8bit alphas, because they just don't look or act nice. :shrug:
Post Tue Jan 26, 2016 1:39 pm
Maybe Abr2Verve could produce vri brush from png too.. :?: I thought about that already. We will see overall utilization and interest in this utility. :)
Post Tue Jan 26, 2016 1:44 pm
Y E S I T C O U L D !!!
Not only that, but your general concept should equally allow to create VRV files from 16bit or any format you can read!
That would be so freaking awesome!
:bounce:
It would buy me some time for sure, hahahaha.... :? :D
Post Tue Jan 26, 2016 1:56 pm
I knew you would say that! :lol:
