PNG export randomness?
Post Fri Nov 13, 2020 2:49 pm
Hey everyone, maybe this is a setting I missed, but whenever I export a 16bit PNG, sometimes it exports as a transparent PNG, and sometimes it exports with the fullbackground, as a flattened image. Is there a way to toggle the transparency when exporting? Or is it just random...
Thanks in advance!
Post Fri Nov 13, 2020 3:06 pm
Re: PNG export randomness?
It will only have a background, if you had given it a background. Certainly isn't random. But all this will change later and becomes a lot clearer, I promise!
Post Fri Nov 13, 2020 3:50 pm
Thanks Taron!
Post Fri Nov 13, 2020 4:08 pm
[CTRL]+[S] will save png as layer without background!
[s] saves the image as you see it together with the background
[ctrl]+[shift]+[s] will save components (color png, material height map (bump map) png)
Memory is coming back to me now. :roll: :hihi:
Post Sun Nov 15, 2020 4:34 pm
Awesome thanks!
