Taron's little gallery
Post Fri Apr 04, 2014 5:49 pm
Re: Taron's little gallery
Thanks you guys! :D
I'm having such a blast right now, it's scary! I just played around with the Smudge Chroma and it truly is surreal. This is a dark blue "primed" canvas and a yellowish white to just draw some lighting on an egg-head, hehe...then I had some fun with the fluidity, of course, but yeah... the tones that come out as you smudge the "egg white" into the black-blue are so amazing. It almost looks as though I knew what I was doing, hahaha...ahh... :oops: Anyway... :D
Post Fri Apr 04, 2014 11:23 pm
Silver surfer revival! :D
Post Sat Apr 05, 2014 2:00 am
Ahaha, yeah, why not! :D
Ok, this one's a bit cheesy, but I just played around with Smudge Chroma and metallic paint...sheeeesh...insane fun! Just a few swooshes and this comes out:
Post Sat Apr 05, 2014 1:30 pm
Fluidity at 100%
Smudge Chroma at 10% (default)
and have at it gently... using all sorts of colors, but then black and white to just do it's magic... my goodness, it's mesmerizing! :shock: :) :D .... 8-)
Post Sat Apr 05, 2014 1:50 pm
I have found something with 2 layers for make a plastic wraping! A little like on your up righ corner ;)
Something like Bump 100%, Metallic 100%...Smudge 100%, and 10% of opacity..layer mode "+" .i must refind the exact trick :oops:
Post Sat Apr 05, 2014 2:29 pm
Ah, you mean like this...
(Copy the layer, turn up glossiness a lot and diffuse a fair bit, turn the layer mode to "+"(additive) and opacity down until all fades except the highlights!)
I've copied it another time and brought diffuse up a lot more, which generates an extra shimmer.
Post Sat Apr 05, 2014 3:07 pm
That's even better... I really played around with the underlying image some more after I copied the layers for the highlights, bringing out the plastic wrapper effect even more! :D
Post Sat Apr 05, 2014 3:50 pm
Perfect that was something like that! ;) But I had not copied the layer ...i must refound it! :D
So maybe some presets will be interesting to have somewhere! :)
Inside the prog or outside!
Post Sat Apr 05, 2014 4:18 pm
Hmmm, later on MACROS might be cool to have. I'm thinking about a certain amount of scripting, too, script recording and all that.
Post Fri Apr 11, 2014 12:34 am
Ah, here's a little test I did based on Knacki's canvas idea! It's quite nice and I think I'll figure out some way of making this finally part of Verve...when I get to it! :)
