Mydrawingsuck's Little Gallery
Post Wed Oct 08, 2014 7:12 am
I'm sure I'll be very inconsistent terms of quantity. I tend to jump around and do various things but I'll post stuff that I do with Verve here.
This would be my dog Cholula.
Post Wed Oct 08, 2014 7:46 am
Re: Mydrawingsuck's Little Gallery
Hehehehe, you like your dogs, that's for sure! Very beautiful! :D
You should share your process sometime, because I absolutely love your approach to fur and admire your precision very much! :ob
Post Wed Oct 08, 2014 11:32 am
Yes, very beautiful and detailed! :bow: The previous version was really great this version is superb! :)
I would like to see your process too! :ob
N.B. if your drawing sucks I would like to see your pictures in the future...
Post Wed Oct 08, 2014 1:03 pm
nice dog, good painted, hope to see more from you ... c:!
Post Wed Oct 08, 2014 1:47 pm
WOW!!! :bounce:
Such detail and brushwork.
Post Wed Oct 08, 2014 3:38 pm
Taron wrote:Hehehehe, you like your dogs, that's for sure! Very beautiful! :D
Actually these are my first two drawings of animals :). I did them to challenge myself to draw animals. Otherwise, I mostly do head portraits. My next goal is to practice landscapes and architecture with Verve. These two are what I usually don't like because of certain components of art I haven't solved.
And thanks for all the kind comments guys. I rarely gush over a software or even have something worth mentioning after using it. I jump around a lot with software because I like trying out new things but Verve is something I'd like to return to.
After work I'll see if I can whip up a tutorial on the fur. It's a bit of a similar approach to what you usually do with hair though painting may require a different technique.
Oh and my name is because that was my first username on the web. I like the idea of testing myself :).
Windows 8.1
Post Wed Oct 08, 2014 5:48 pm
Very vivid! c:!
Post Thu Oct 09, 2014 4:37 am
So here's a mini Tutorial. I'm not great with these so bare with me.
This is the brush settings I use:
Brush type: 9
Minimal Size: whichever that allows you have bristles visible when you start your stroke
Build up: 12%
Bristle: 23%
Fluidity: 10%
Everything else: Default
So on the bottom right, you can see the brush strokes. Quick, fairly light strokes allows the bristles to show. The ends do look cut off but you can always go back and blend the ends down. I don't have Oppacity on because that would be too soft of a result.
So I looked for the common colors and placed them down. Than I come in and blend out the edges to push and pull color boundaries deliberately so it looks like overlapping fur. You don't want to go over the same spot too much otherwise you get really soft blend. Than I came back in laying down more of the apparent color furs. I'm not perfect in finding which colors to use so my palette at times tends to get bigger.
I than come in for some of the secondary colors. It's more of looking at the reference and seeing the darker and lighter values. Lighter values tend to be unique from the photo or the Highlight color. Highlight Color tends to get mixed and used around the whole painting. Some of the darker values are from the dark common colors so the grey you see is actually sampled from the little mixing with the lighter value. This digital part really helps in quickly getting variations instead of going to the color palette and mixing up colors.
So now comes the shaping of the fur. The main take is:
-Fairly light strokes to reveal bristles
-Sample darker and lighter values of the surrounding fur.
-Even stroke blends to extend and pull the fur.
So here I color sample around some of the dark areas to get a semi 50/50. Take this and add in depth to the base areas and also the secondary colors. This breaks up base colors and add variation, and I don't have solid light areas, base colors, and secondary colors anymore.
Same idea with Lighter values and this tends to be the primary Highlight Color. Usually this is too strong for most areas so get a toned down version of it. What I do is lightly brush it in the area I want at the ends of furs, sample a 50/50 color of it and than knock that area down with the color I want.
Fur is all about overlapping so you want to gently stroke-blend the ends of furs so they are are over a darker or lighter area. Lightly blend stroke-blend the areas.
Windows 8.1
Post Thu Oct 09, 2014 7:14 am
Great job! That's a sweet little tutorial, THANKS! :ob
It's pleasant to see with what ease you work such subjects and how natural you connect with Verve. Feels like you've been working with it for ever! :o ... :bounce:
Thanks for sharing this, really, you rock! :rock:
Uh, Ah, man, you gotta make a Vervatar, too, though! I just realized that's what's still missing, hehe... 8-)
Post Thu Oct 09, 2014 8:29 am
Great tutorial! Thank you. It is very helpful! :ob
